Hi Niels!
The standard G-Code is corrupted/wrong formatted.
Please try this… At the Printer Settings…
Replace the G-Code for START and END with following Code.
Start G-Code:
; Vertex Nano Start G-code
M400 ; Wait for current moves to finish
G28 ; Home extruder
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
M104 T0 S{material_print_temperature}
G92 E0 ; Reset extruder position
G1 Z15 F800
M109 T0 S{material_print_temperature}
; Priming nozzle…
M83 ; Set extruder to relative mode
G1 E20 F50 ; purge/prime nozzle
G4 S3 ; Wait 3 seconds
G1 Z5 F2000
End G-Code:
; Vertex Nano end G-Code
M107 ; Turn off fan
G91 ; Relative positioning
{IF_EXT0}T0
{IF_EXT0}G1 E-1 F1500; Reduce filament pressure
M104 T0 S0
G28 ; Home extruder
M140 S0 ; Disable heated bed
M84 ; Turn steppers off
