Probe for K7000
Hello, I just assemble a K7000 kit, signal tracer. I am looking for probes but it seems Velleman does not provide them. Very strange, may be I am wrong ??
Thank’s for help
You don’t NEED to use special probes, you can also work with one ground wire with crocodile clip and one multimeter test lead as probe?
However, you an also use a real scope probe: probe60 or probe100 are the cheapest solutions here. But be aware of the fact that the wire inside the scope probe lead is very thin, so use a very good strain relief to avoid that the cable breaks regularly at the point where you soldered it to the kit.
