Printing with nylon filaments
Not so much an issue but was wondering whether anybody has tried printing with different materials other than PLA or ABS. If so can you share your experience.
Many thanks
I needed a replacement landing gear for a micro RC-helicopter as PLA was way too fragile. Tested Taulman Bridge with temperature 245, bed 65 (takes ~20 minutes with a glass plate and the heating not flipped upside down), speeds at 15 mm/s.
First print I applied some glue stick to the bed, but I forgot it with the second print and it went just fine. Though, the landing gear is small and this might not apply to bigger objects.
First print also had some “explosions”, probably from water. Second print went fine.
First print smelled awful, second print was fine.
