Hi , witch of the two pots are "1M pause " the 1M803M or the 5CK740M ? On the picture they have different colors the two i have are black ?? The r2 has on the solder site only one copperlead but the other (leadless hole) is verry near to two pins of the chip ,how to solder ??
Thanks in advance
Potsy
ps sorry , first timer ,subject = MK111
Read the printing on the pots carefully…
One reads 1M803M while the other one reads 5CK740M
Now, which one would be 1M ?
Thanks for speedo answer ,how about the 3 holes ?
grtz Potsy
Sorry, that part of the question is not clear.
Please explain.
Hi ,if you turn the pcb on the soldersite r2 is near two pins of the chip should they be soldered together or only one pin because the resistor hole has no copperlead Q is witch pin ?
grtz Potsy
If you are not sure, use a multimeter to determine if Pcb pads are connected or not.
It works , thanks for helping me out
Potsy
