PCSU1000 usb isolation
If someone could please help. I am an electronics noob with a new PCSU1000. I do not want to run the risk of damaging my PC and want to isolate the scope from the PC. The specifications of the PCSU1000 state that it requires a USB 1.1 or 2.0 compatible port. My question is - Is the full functionality of the scope available at USB 1.1 speed? The reason I am asking is that USB 1.1 full speed isolators are readily and cheaply available. I would like to avoid spending on a USB 2.0 high speed isolator if possible, since they are considerably more expensive. Your help is much appreciated.
[quote]My question is - Is the full functionality of the scope available at USB 1.1 speed? [/quote]Yes, it is.
Thank you. Your reply is much appreciated. This could be helpful to others as well.
