Same procedure as years before: Software, in detail drivers are not recognized by Win 10!
System: Microsoft Windows [Version 10.0.18363.752] , i. e. Windows 10, Version 1909, 64-bit, the current version, doesn’t recognize the drivers for the PCSU1000.
Device manager tells about an unknown manufacturer for the USB Serial Port. Software is installed as provided from the velleman pages pclab2000se_v4_07_setup.exe.
As previously found, the USB cable has raised problems, such a trial was made with three different cables withotu success.
USB-Viewer from MS shows the reason:
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : PCSU1000_Oscilloscope
Device Path : \\?\usb#vid_10cf&pid_1000#yel952tl#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_10CF&PID_1000\YEL952TL
Hardware IDs : USB\VID_10CF&PID_1000&REV_0400 USB\VID_10CF&PID_1000
Driver KeyName : {36fc9e60-c465-11cf-8056-444553540000}\0023 (GUID_DEVCLASS_USB)
Driver : \SystemRoot\system32\drivers\ftdibus.sys (Version: 2.12.10.3 Date: 2018-02-12)
Driver Inf : C:\Windows\inf\oem15.inf
Legacy BusType : PNPBus
Class : USB
Class GUID : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Service : FTDIBUS
Enumerator : USB
Location Info : Port_#0001.Hub_#0003
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(5)#USB(1), ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HS05)#USB(1)
Container ID : {14f24315-ddef-56d8-bba8-d0cdf313dab6}
Manufacturer Info : FTDI
Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
Address : 1
Power State : D0 (supported: D0, D2, D3, wake from D0, wake from D2)
Child Device 1 : USB Serial Port
Device ID : FTDIBUS\VID_10CF+PID_1000+YEL952TLA\0000
Problem : 28 (CM_PROB_FAILED_INSTALL)
MS tells in [https://docs.microsoft.com/en-us/windows-hardware/drivers/install/cm-prob-failed-install]
Recommended Resolution
Please visit the website of the company that manufactures the device and look for the most recent drivers for this device.
This was done without success.
Later I’ve found the crazy solution: Disabling the USB-Serial-Port in the device manager made the PCSU1000 or the PC-Lab2000 application running. The Oscilloscope is found under USB-Controller with a driver version 2.12.10.0 from 28.10.2015, while in the USB-View output \SystemRoot\system32\drivers\ftdibus.sys (Version: 2.12.10.3 Date: 2018-02-12) quite another release date from 2018 is shown. A chaos!
USB-View now tells:
Problem : 22 (CM_PROB_DISABLED)
But this was only a one-shot issue! Closing PC-Lab and restarting the same shows in the primary menu the toggle “USB-Device detected” checked, but starting PCSU1000 tells “No hardware response” and starts in Demo mode. Unplugging and replugging the USB-Cable in this state is without success. Even if PC-Lab is closed AND in that state the USB-Cable is unplugged and reconnected PC-Lab will no longer find the USB-hardware. I haven’t checked if a reboot will solve this.
