Thank you for your comment concerning the PCSU1000 oscilloscope.
At the moment the PCSU1000 scope remembers only the probe settings x1/x10.
You can anyhow save and restore the other settings using the File menu options “Save Settings” and “Recall Settings”.
Save Settings saves the oscilloscope, spectrum analyzer and transient recorder settings to a file. If you have a function generator PCG10 then also function generator settings (frequency, amplitude, offset and duty cycle) are stored to the file.
Recall Settings loads a previously-stored settings file to the oscilloscope.
[quote=“VEL255”]Thank you for your comment concerning the PCSU1000 oscilloscope.
Recall Settings loads a previously-stored settings file to the oscilloscope.[/quote]
Indeed, I was aware of that feature, but this is not what I call a “last status”.
Such feature should save the current settings automatically on exit and should recall those settings automatically when restarting the DSO.
Maybe also something to add to the “improvements” list?
Indeed, the save settings to file is rather complicated.
There are also cases when you do not like to start from the last settings. Mainly if there are other users of the scope.
Maybe there should be put to the Options menu “Save/Recall Last Settings” option. Then you can select if you want the scope to save/recall the settings or not.
This option will be considered for the next update.
