Downloaded PC-Lab2000SE and loaded it, selected PCS100 and disabled plug and play. It gives the error message “Could not open DriverLINX driver Please run INSTALL.DRV.EXE to install driver”.
System:
Desktop
Windows XP
Administrator
parrallel port set to normal in BIOS.
Intalled the driver and still doesn’t work. When running Pc-Lab2000 always failed to calibrate as well. Tried deleting WinDSO.ini.
Have you tried the slow communication speed for the scope from the Options / Hardware Setup menu.
Also you mentioned that the LPT port is set to normal mode in BIOS.
What are the other alternatives for the LPT port modes in the BIOS?
