PCS10 as 4 channel voltage acquisition device?
Hi all, I’m a newbie and I’m a bit confused by the large Velleman portfolio offering…
I need to measure 4 channels voltage (from mV to 40V) using my laptop:
is PCS10 the matching solution for this requirements? Is required any other device connected to PCS10?
Are there alternative devices in the catalog offering which are close in features?
thanks!
The PCS10 can be used to measure ground referenced positive voltage.
The lowest voltage full range is 3V. The resolution is 8 bits.
Here are the main specifications:
  • four input ranges: 3V / 6V / 15V and 30V
  • sensitivity: 10mV
  • accuracy: ±3% of full scale
  • maximum input: 30Vdc
If you need to measure mV level signals you need an external amplifier.
There are no alternative 4 channel data recorders in the catalog at the moment.
