I’m using a PCS10-Recorder to check an external battery voltage. In the software pclab2000se is the max. time/Div. = 1000s. I’m using autosave and would like to measure the voltage only every hour to avoid large files (I need to transmit them via GSM). Is there a possibility to adjust the Time/Divison to for example 1 hour?
Thanks for any response and greetings from Switzerland,
Markus
