I have a PCG10 and a PCS100 but the Scope has never worked. I am thinking of replacing it with the PCSGU250 but still using the PCG10 function generator as it has 1MHz capability.
I am slightly concerned that this is not possible due to PC LAB 2000 LT edition, is LT a cut down version that won’t work with the PCG10 ?
Indeed, you can’t run the Bode Plotter with the PCG10 in this case.
You have to use the Function Generator of the PCSGU250.
The PCSGU250 Bode Plot is up to 1MHz.
Also the sine function is 1MHz.
Square and triangle 500kHz.
