Pclab2000 problem
Hi i have a problem, i install a pclab2000 software version 3.03 under winXP, but i can’t install it, i have winXP, i try to download another version, but it’s the same, when i run setup.exe the installation progran don’t start.
helpme ! :frowning:
Have you extracted the pclab2000se_3_03.zip to a temporary folder and then run the SETUP.EXE there?
What kind of error message you got - if any?
BTW: Do not extracted the files to to a folder with too long path name:
Extract the files simply to folder C:\TEMP\
[quote=“VEL255”]Have you extracted the pclab2000se_3_03.zip to a temporary folder and then run the SETUP.EXE there?
Extract the files simply to folder C:\TEMP[/quote]
yes, i have extract in a folder and i have run setup.exe, but don’t work, i haven’t an error message, the cursor on a screen is blocked
now i use a pclab2000 version 1.30
i tink tha the problem is the file:
wowexec.exe
setup.exe
the process in the task manager is always running, because i can’t erase the file before to finish the process.
It seems that you have similar problem as described in this link to other forum:
community.macrovision.com/showthread.php?t=96525
Seems to be difficult problem to solve. There is a “semi-solution” described at the bottom of page 1.
On page 2: “Safe mode works. Not a solution but a work-around.”
