PC Lab 2000 SE Possible Bug and new feature suggestion
:?: I just received my PCSU1000 and am running v. 3.05 of the software. It seems like the saved DSO text file is not saving all of the data in the history, it appears to only save the last time slice. Is that a bug or just the way it works? I would think it should save the history as well, but mine does not. When opening the saved file after restarting the application, only the last time slice appears, the history is blank.
Also, it would be nice if it had a “CLEAR HISTORY” button to clear it as well. The only way I can find to do that now is to exit the application and restart it each time. Seems like there should be an easier way.
Thanks.
Thank you for your comments.
The history file will be quite big, about 56 MB.
Anyhow these both are good ideas: A file menu options “Save History” / “Open History” and a button “Clear History” should be added to the future version.
Thanks for your prompt response and the consideration of adding these features to the next release. Is there a way to be notified of the new release being posted on your site? I’ll check a little closer on the site myself. Thanks again!
To check the updates the only way is to visit Velleman downloads site at the moment.
