I built p8076 and it’s well running ( hardware tests are OK ).
I put a PiC 18F2550 and made connexions as described.
Green led is on
Pic is well connected ( pin 1 PIC in pin1 socket )
When I load an HEX file I have the following mesage :
" the settings don’t mach the PIC "
I would be pleased if you could tell me what I made wrong.
Thank you in advance for your help.
Best regards
Patrick[/quote]
Hi, Patrick.
I am not an expert, but can it be, that you’re trying to load sample blinkled.asm that came with the soft installation? If so, then the problem is, that it’s for 10F200 chip, not for 18F2550.
