I have a K8028 and a VM 101, both the same design dimmers. But I want to use these dimmers as a slow ON, slow OFF dimmer. When I close the switch, the dimmer must go UP, when I open the switch, the dimmer must go down. This doesn’t work with both dimmers.This is function 5. Function 4 is not working also. With both dimmers. When I look at the manual, function 5 and function 9 have the same LEDs on (LD1-LD4). This looks like a programming error.
Can you give me a short description of what I have to do to get a slow ON/slow OFF dimmer? I really tried everything.
