MK180 - presales information
Hello all,
i’m interested in the new minikit MK180. But, I have 2 questions that I like to be answered before buying it.
  1. In the information sheet, there is stated that a hi-power led (6-square shaped model) can be attached instead of the included 4 leds.
    Can this kind of let be connected directly to the output or do I need some resistors? Or does it mean that the included leds can be replaced (like with cable extensions to the solding points on the print)? I would like to connect 1 hi-power (again the 6-square shaped model) led on each channel.
  2. What are the flash patterns? Along with the more flashier patterns, I would be happy with a simple steady on-of (like a car-flasher).
Thanks for the reply!
You need current limiting resistors.
Flash patterns are not documented. Simple on/off flashing is available.
Ok,
this module is just perfect. Realy bright flashes.
Just one more question. Can I build another pair of led boards as they are provided with the kit and place them in parallel with the originals? It’s my intension to have 4 flashing points.
Thanks again!
That should not be a problem.
Outputs are rated at 3A
