gorhamj
November 19, 2010, 10:57am
1
I currently have a MK179 PROXIMITY CARD READER which I am experimenting with.
I have made my own loop and extended it on a 5 meter cable and it is working well.
Is it possible to add on a remote switch to replace or replicate the function of the switch on the board.
Could you send me the schematics for the board and any advice you have on achieving this.
VEL417
November 19, 2010, 1:04pm
2
Diagram has been sent to your address.
We do not recommend to put the button at a remote location, as the input is not buffered.
If you use a relay, it will work.
gorhamj
November 19, 2010, 4:10pm
3
I purchased the kit ready made and I am unsure which connections to add the relay to.
The switch appears to have 4 connections pins and I have no details about the switch.
Which connections do I attach the relay to to replace or bypass the switch.
VEL417
November 22, 2010, 8:02am
4
Look closely: the contacts that are closest to eachother have to be bridged.
gorhamj
November 22, 2010, 9:57am
5
You do have to look very closely !!!
But I found them and it is working great, Thanks.
