MK178 bypass
Hi
I want to add an off board spst switch to bypass the flashing so i can use the 3rd brake light as a normal brake light ( for m.o.t purpose :unamused: ),
where would be the best places to “short” out i was thinking of - to -
many thanks
steve
I don’t have the schematics but it seems to me also that the load is switched to ground so a switch between -out and -in could work. For safety: wait for an answer or schematic from Velleman.
Looking at the schematics it does look like it does switch to ground.
You can find the schematics at the link below.
http://www.velleman.eu/images/tmp/Diagram_MK178.jpg
Enjoy
Yep, it does switch to ground so a switch between out- and GND will work.
Hi many thanks thats what i thought
CAUTION : there is a mistake on the diagram.
R4 is NOT connected with IN+ (not a node but a bridge).
R1 and R4 are in series with the LED.
Regards
Don’t know which version of the PCB you have but I’ve taken a MK178 with PMK178’1 as PCB and there R4 IS connected with IN+
Sorry,
after check in detail of my own PMK178’1, I think the little track between R4 and IN+ is broken.
So, yes : R4 is connected with IN+.
My apologies
