MK161 No respons
I have same problems with MK161 IR Receiver. Everything is working exept the receiver.
When I turn power on, LD1 flash once.
If I hold “Prog” while turning on, LD1 flash 3+2 times.
When I press prog LD2 and LD3 is changing and the relays “tics” and after about 10 sec LD2/LD3 go off.
When I press the button on the remote nothing happens, I have tried with several different remotes/buttons.
Any suggestions
Are you sure you are using the Velleman MK162 remote ?
No, can´t I use any remote? Does it have to be MK162?
I thought I could program the receiver to response to any remote, like Logitech Harmony 525
Please check the specs of the kit (http://www.velleman.eu/be/en/product/view/?id=351213)
It is only compatible with certain Velleman remotes.
Of course, if your remote is a learning remote, you can learn the Velleman remote to your remote (if you have a Velleman remote).
Ok. Then I understand. I have to do it the other way, learn the remote instead of the receiver.
It’s not necessary to have a Velleman remote because Logitech have MK161 in their database.
Thank you very much for the help!!
