Mk160
Hi! I have just finished a project where the MK160 drives a horn for 2 secs in order to scare wild animals from my garden.
Problem is that it seems to take wery long time before the unit resets and you can call again to trigg it. If i cut power to the unit, it resets, but I want to make several calls every night when I´m not at home!
Any Ideas?
Thats weird, because in the software, there is no delay before you can re-activate the unit after turn-off of the relay.
Btw, wouldn’t an interval timer such as K8015 be a better solution, that would avoid having to call every now and then.
http://www.velleman.eu/distributor/products/view/?id=341552
Well! The idea is that I should be able to trigg it at different times every day, that is why i choose this instead of a timer. I´ve tried it yesterday and it triggs one time and then you have to cut power to reset it. Could I just try and replace some of the IC:s?
Maybe it is power supply related.
Can you try with just the kit, nothing hooked-up to it.
