MK160 Relay Rating
Please can you confirm the maximum AC and DC voltage for the MK160 output relay. I see it can handle 3 Amps but will it safely switch 230Vac mains?
Should not be a problem.
I’d like to control light bulbs and neon lights that together use up 100 Watts at 230 VAC, can I do that safely? I already tried to switch 100 Watts for a few seconds, so far I had no problems. What would be the maximum amount of Watts for the MK160?
MK160 is rated at 3A, so at 230VAC that would be 230x3=690W (resistive).
Make sure that the unit is installed according to the rules of good craftmanship.
Thank you for prompt reply.
