MK139 Complete malfunction!
Hello, I recently bought the MK139 Velleman Clap ON/OFF Switch and assembled it, to my eye, perfectly.
However, when I connect the power supply, the clap LED is constantly on. To check the PIC I have disconnected them and the light goes out, therefore I know that they work fine. But after trying everything mentioned on other similar posts, I still have no success.
Is there any way I could possibly send you my circuit board for you guys at Velleman to inspect and make sure it is all OK?
Thanks very much for your time
FIlip Harding
Yes, no problem.
Normally you must send your defective kit via your dealer (reduce transportation cost and risk)
if not possible, you may send the kit to:
Velleman NV
attn. KIT repair dept.
Legen Heirweg 33
9890 Gavere
Belgium
