Heey
I’m re-aranging my room and I wanted to implement a clap-switch
so the rgb ledlights will turn on when i clap my hands
but the cheapest ledlight i could find are not 24v as the output of the relay…
is there i way so i can change the relay and put 240v on it with an adapter between it ??
Best regards Senne!
Hi Senne
The relay is rated for 240V. But i think the terminal contacts aren’t spaced far enough to be safe for 240VAC i guess
