Complete novice here!
I have made up the MK133 and all works well except on switch 4. When switch 4 is pressed both LD4 and LD5 light up, but the light goes out as soon as SW4 is released. I have a brand new battery and have double checked diode orientation, also checked that the correct transistors are fitted to the right locations. It could be bad soldering I guess, but I don’t know what is good and what isn’t!
Here are the links to pictures of each side (Hopefully!!)
