is it possible to change the flash rate from 4 flashes to just one flash -
for instance by changing the value of C2?
if so, which value for C2 do I need?
what I would like to achieve is one flash; off (no flash) for anything between 1 and 4 seconds.
thank you
Günter
Rochester, Kent
U.K.
VEL417
October 11, 2011, 11:30am
2
Tolerance of a cap can be up to 40%, so you will need to experiment for best results.
I am not very good with electronic circuits but can assemble a kit with instructions.
The MK126 produces 4 quick flashes every 3 or 4 seconds.
If possible, I would like to change this to 1 flash (instead of 4)
What I would need to know is:
what do I need to change ?
change C2 from 1uF to 2uF ? (or other value?)
and/or change any of the resistors? (to what value?)
I would be grateful for any help
perhaps someone has done this before?
GM
VEL417
October 12, 2011, 12:17pm
4
You could try reducing the value of R13.
Sorry, no values, please experiment.
There is no risk in harming the circuit.
Tavo
May 7, 2012, 7:34am
5
Bonjour
Suis possesseur de ce kit qui fonctionne bien et suis interessé par ce post.
J’ai pas bien compris faut-il changer le C2 et la resistance R13 ou uniquement la résistance ?
D’avance merci pour votre réponse…
Tavo
May 17, 2012, 4:56am
6
[quote]You could try reducing the value of R13.
[/quote]
Bonjour,
Doit-on uniquement remplacer la résistance R13 ??
Merci de votre réponse…
You could start experimenting with R13 only.
Tavo
July 17, 2012, 12:45pm
8
Avec beaucoup de retard …Veuillez m’en excuser…
Je vous remercie de votre réponse…
Cordialement…
