Does anyone have the circuit diagram for MK125 rev1?
I’m trying to use this module to switch on a garage light when the door is opened, obviously when it’s dark outside. I have a magnetic reed switch on the door that goes open circuit when the door is opened, I want that to use that as a trigger.
Anyone any ideas?
Thanks for your reply, I appreciate it.
Sorry, I must be missing something. I downloaded the manual you suggested, it has a layout drawing but I can’t see an actual circuit diagram.
I could draw it out by following all the tracks on the board but that’s not easy to do.
I must be thick, but all I can see on this assembly manual, bottom RHS, is a drawing of the board layout. I’m looking for an electronic circuit diagram that shows how all the components are interconnected.
Are you looking for the PCB layout ?
I’m sure you’ll understand that we do not supply PCB layouts.
After all, our business is selling kits, not supplying information so that people can copy our circuits.
