MK120 use to trigger a MP3 player
Is it possible to use this kit to trigger a mp3 player (such as the sparkfun mp3)
My idea was to leave the buzzer out of the circuit and to use it as a trigger to play MP3’s. I would like to connect the + and - (where the buzzer should normally be) to the + and - trigger input of the mp3 player but I do not know the output VA of the + and -.
These kits would be useful in our museum ie if someone passes the MK120 than een audiofile on the MP3 player would start to play. Can I change the frequency so multible MK120 could be used (the sparkfun MP3 can be triggered 18 times via different “IR eyes” or something like that. I would make it myself to cut costs (as we are a starting young museum without loads of cash)
Good or bad idea? Any other sugestions are obvious more than welcome.
Thanx
Steve
Most likely, the MP3 player needs a contact that closes as a trigger.
You can replace the buzzer with a small relay. Make sure to put an 1N4148 diode over the relay coil.
No need to change the frequency of the MK120, as the IR beam is extremely narrow.
I’ve got this wired up via a 12v relay too to trigger a talking pumpkin for halloween … what is the purpose of the diode? Does it matter which diode? Will a 1N4007 work also?
Yes, an 1N4007 will do too.
It protects the transistor.
