MK120 supply voltage
I’m sure you’ll understand that we are not aware of the Mapin range.
You can check the Maplin catalogue and check for a 940nm 5mm phototransistor.
If necessary, contact a different distributor.
The one I tried (linked to previously) did cover the range that includes 940nm,so why didn’t it work,or more to the point what other parameters need to be the same?
