I have MK120 Light barrier and it works fine, I would like to run it from 12V DC power supply.
These are given specs:
transmitter emitter: 9Vdc, 50ma max.
receiver detector: 9Vdc, 20ma max
So to run at 9V DC I need to add 43Ohms resistor in series to get 9V from 12V?
Or can I run them from 12V directly?
Or perhaps it’s better to change some resistors on PCB, if so what components needs to be changed?
I have another question:
This detector will be used when the transmitter and receiver LEDS are close together 2cm.
How can I adjust sensitivity? What resistor needs to be changed with POT to adjust it?
