Mk120 IR Light Barrier how to adjust sensitivity
is there a resistor I can replace with a potentiometer to adjust the sensitivity of this IR beam break alarm? :question:
(MK120 Beam Break Kit)
Schematic is here:
http://www.velleman.eu/downloads/files/schema/receiver.jpg
thanks
Kit ‘as-is’ is at maximum sensitivity.
You could increase the the series resistor of the IR leds to reduce sensitivity.
Sorry, no values, please experiment.
ok, another question, why are there two IR leds in the transmiter instead of just one?
More leds = more power.
is the IR output modulated? If so, what freq?
and does the detector look for this?
yes, it is modulated (see schematic diagram).
freq: a couple of kHz (this has not been measured).
At the receiver end, the signal is filtered.
