Mk118
[size=150]I’ve just constructed the MK118 FM radio kit. When I switch the device on (using the required 12V power supply) there is a low amplitude hum and I cannot tune into any radio stations (even when I vary the correct variable resistor). Do you have any ideas as to what is causing the problem?[/size]
Did you use the ‘search’ function and read the various posts on this subject ?
