Mk118 problems
I saw that in another topic you refered to pin 4 on the FM front end, where is that? :stuck_out_tongue:
Also, how should the antenna wire be connected?
All pins of the metal front-end should be soldered.
Antenna wire is connected at solder side of PCB.
You can leave it hanging in free air, and move it for best results.
