MK118 FM radio only receives RTBF première
Still I would like to try other things if possible
Any means of detecting if PreFM circuit is OK anf FM demodulator is OK.
I have only a voltmeter to test things.
Do you have the adress of a supplier in Brusssel to replace TBA120U???
Thank you
There is not much you can do with a voltmeter, except checking if all parts receive the required power supply and you can check the tracks and connections for continuity.
Your Velleman distributor can supply spare parts
