Hi - have this kit - but unclear as to which is which ?
1M803M ? RV1
5CK740M ? RV2
Thanks for your help. :?
1M803M ? RV1
5CK740M ? RV2
Hi zimrabbit,
I would simply ask you to look for an ohmmeter or a multimeter to check the resistance of the potentiometer at the ending points.
RV1 should measure 1,000,000 ohms or 1M ohms.
RV2 should measure 47,000 ohms or 47k ohms.
I hope that this humble hint will be useful to you.
Good luck in your project.
Keep well.
M I Joomun
Cheers - there is always a simple answer !
