My MK111 doesn’t work properly.
It will always close the relay unless both RV’s are completely turned to the left.
When I adjust the pulse the LED just stays on and the relay starts to make a buzzing noise.
When I adjust the pause, it just stays on too.
And even when both RV’s are completely to the left it doesn’t do what its should, then it goes on and off very fast (too fast).
Until it slows down and eventually stays on all the time.
Most likely an assembly problem.
Hard to troubleshoot without actually being able to examine the unit
If you can post links to hires and sharp pictures of both solder and component side, maybe we can give a hint…
