MK110 Grounding
Hi there. I am looking at the diagram for correct wiring on the cardboard case thing that comes with it.
There are only two leads going to the light bulb and only two going to the plug.
I’m in the UK and we have three pin sockets here with the addition of a ground pin on top of the usual ones. Do I need a ground in this circuit at all to avoid massive electrocution from the mains? If so where do I connect it.
One other question, I want to use this for a keyboards output, would I need to go through a DI box to get the correct voltage going into the circuit?
Hope you can help.
N
If you need grounding, ground the bulb fixture.
Sorry, no clue what a DI box is.
The circuit needs a couple of watts to operate.
So to ground the light fixture I would simply have to connect the ground socket on the light fixture to the ground pin on the plug?
DI box - http://en.wikipedia.org/wiki/DI_unit
N
Yes.
