MK107 switching more than 7 led's
Hi there, new to all this but here goes.
I bought the MK107 to drive an enlarging circle of LED’s rings for a school project 4 my daughter and her christmas play
IE
o/p 1 - 7 LED’s
o/p 2 - 9 LED’s
o/p 3 - 12 LED’s
o/p 4 - 16 LED’s
o/p 5 - 21 LED’s
o/p 6 - 27 LED’s
o/p 7 - 34 LED’s
o/p 8 - 42 LED’s
Can anyone in very simple terms, tell how I can switch this many LED’s using a transistor. The effect that is required goes something like this
ring 1 off - 2-8 ON [color=#0000FF]1[/color] [color=#FF0000]2 3 4 5 6 7 8[/color]
ring 2 off - 1 , 3-8 ON [color=#FF0000]1[/color] [color=#0000FF]2[/color] [color=#FF0000]3 4 5 6 7 8[/color]
ring 3 off - 1-2 , 4-8 ON [color=#FF0000]1 2[/color] [color=#0000FF]3[/color] [color=#FF0000]4 5 6 7 8[/color]
ring 4 off - 1-3 , 5-8 ON [color=#FF0000]1 2 3[/color] [color=#0000FF]4[/color] [color=#FF0000]5 6 7 8[/color]
ETC through to output 8
I believe it might be a PNP transistor from what I have read but dont have a clue how to wire or work out what to use
Many thanks from both of us in advance
Steve
Maybe the K8044 is better suited for your application?
http://www.velleman.eu/products/view/?id=348779
Thanks for the reply
BUT would the kit produce the effect required ?
I have tried searching for the effects but with no luck
Unforchantly it does not answer my question can the output be reversed?
Cheers Steve
You can download the the usermanual for the VM120.
Same item just assembled.
This shows the different effects.
You can download it from the following link.
http://www.vellemanusa.com/support/downloads/?code=VM120
Hope this helps.
Most likely, effect 8 is what you are looking for.
