MK 195 and arduino
hi,
is it possible to command the kit with an arduino ?
i order arduino with a rf remote and i would like to command buttons (volume and play) with it
thank you for your answer
regards from France
Yes you can solder it with the outputs.
But may i suggest a solution made for the arduino the KA02
VEL337
hi
i suppose the kit can be command because there is an emplacement “K2, external control”
what kind of device can i install here to command the kit ?
regards
Just wire up the the kit to the arduino but remember a 0 ie connection to GND will activate an action.
As seen in the manual
vellemanprojects.eu/download … _mk195.pdf
