Hi All
I have used the MK 125 Mini Kit to control the interior lighting on a bus very successfully. The only problem is Bus electronics are 24 Volt and I have to use a stepper to reduce the voltage .Is there a kit for 24 Volts or an easer way to convert to 24 Volt
