Mk 124
HI ,
I have a MK 124. all seems to be working except for the bottom row right 6 leds. (the most left led is working). What is wrong?
Kind regards
Maurice
Just a guess,
Did you install them backwards?
Hi Wrong Way,
You refer to the leds? I don´t think so, but I will swap 1 to see/check.
Maurice
If you look through the side of the LED you will see a flag in it.
Compare a working one to one that is failing.
It’s a lot easier then swapping the LED.
Hi Wrong Way,
I checked the leds. These are put in the correct way. So that is not the issue. What else can I do / check?
Maurice
