Kit K8039 Transformer pins
I have bought 7 of this kit I have most of them built. I have found that the pins have bent on the transformer when in the packing. I have 2 kits that the pins were very badly bent on the transformers that they snaped off when I tryed to straten them. one is ok as it was a pin that was not been used and the other one is no good as it the mains side and it the 0v pin that gone.
I feel that there should have been some of the spung on the transformer to protect the pins.
Tony
Thank you for your feedback.
Altough we did not received any complaints, we will look into this.
I also forgot to ask is the transformer “standerd” as in the pin layout of the transformer as I am short one that one of the pins have come off.
If the transformer is not standerd where can I get one from.
Tony
This is a custom transformer.
If yours is defective due to transport, please return it for exchange to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
I feel it more to do with the way the tramsformers are been packed in to the box. The pins are sticking in the paper and if it get a small bang with the wight of the transformer the pins bend. The pins of the transformer should be protected in ISOMO.
I will not be returning the transformer as it will cost the same price of the kit to post to back to Belgium. I also feel that support do not believe me. I do not have the pin of the transformer that snaped off when I tryed to straten it as left it aside and went on building the rest of the kits I had.
I am also planning to buy more of these kits as I can get them cheeper than posting the transformer back, when I buy the qty of 7 or more.
Tony
I’ve send you an email…
