K8800 Belt Upgrade
Hi all,
I just purchased myself a Vertex Delta for quite cheap and was interested in doing some potential mods. It’s already got a linear bearing mod on it though I’d like to swap them for Polymer bearings another user had suggested.
I’m most interested in upgrading the motors, be that the motor itself or adding in smoothing/damping curcuits to make them quieter.
Likewise to reduce noise and vibration upgrading the belts. I’ve noticed that all the belts, although tensions pretty much as hard as I’m willing to pull them, rattle and vibrate an awful lot. I’d like to change them to a rubber fbg reinforced.
Has anyone had any experience doing this??
Thank you!
Has anyone got any ideas?
Hi ryv,
I made spanners with a m6 bolt at the top works great, also 6 springs under the bed let 3 screws away, so I can level with 3 screws. Also upgrade to Marlin 2.0
No vibration and noise here.
Kind regards,
Tom
Hi Tom thanks for the reply,
How do you level the glass bed? Have you got any pictures of your spring solutions I dont think there’s quite enough room for that in my k8800
I need some help with how to get marlin 2.0 as well, do I need to write it myself or can I just download it from xyz?
Thanks!
Ryv
Hi ryv,
Look here:
https://forumtest.whadda.com/t/printing-only-on-the-rightside-of-the-printbed/35013/7?u=tome
But i use just 3 springs and 3 screws for leveling.
For the spanner i use also a .stl file i got from Willem Waalre, i shall put it online with some other stuff.
For Marlin software, I used the info there.
You hear from me.
regards,
Tom
Hi ryv,
for the spanners, you can download here:
Kind regards,
Tom
Hi Tom,
That’s brilliant thank you so much for that!
If you do not mind, can you clarify why you only use 3 sprung screws rather than the original 6? i presume its very difficult to balance the bed between 6 screws.
Additionally where did you get your heated bed element from? Is it quite plug & play?
Thank you again!
Ryv
Hi Ryv,
correct about the 3 screws, with 3 good result leveling.
And not plug and play, you need also 12V 10A DC adapter (mine AliExpress) i got a case as stl for the print. And i made it that in the printer it has a plug to connect it easy.
Kind regards,
Tom
Hi Tom,
That’s great thank you, unfortunately i cant access either of those two links you sent.
Ill have another look around and see what i can find.
All the best,
Ryv
Hi @ryv
Here some pictures,
Where are you from?
Here Amsterdam.
Kind regards,
Tom
Je kan ook hier de sensor kopen: Digitale Thermostaat Module met Relais - XH-W1209 - XH-W1209
stuk goedkoper!
