K8098 front panel cutout
Hello
I built this kit tonight and it does work great but the problem i had was aligning it with the front panel, i can get it to fit great but then the mode switch will not work as it’s jammed at an angle, playing with it to center the switch leaves the display a little low showing a bright band from the backlight, it’s not in the active area of the lcd but it is distracting, i am going to use some black plastic to mask this but i thought i would mention it, the area that shows the back light is about 1mm across the top. I am happy with the device otherwise
thanks
Chrysophylax
Thanks for your feedback.
You are correct, aligning it is not straightforward and requires some trial and error.
