I’m considering buying the K8095 MP3 player kit, but I can’t find any reviews, just people on this forum asking for help, especially with the display, it seems?
Anyway, I was wondering, is it any good? Can it run high impedance pro headphones comfortably? Like 250 Ohm Koss Pro4AA?
What is the sound quality like?
Any of you guys have any photos of the player in any enclosures?
More of a technical question: Is it easy to move the SD holder to a different position, using a ribbon cable or something?
Should not be a problem to put the SD card in a different position but make sure to keep the wiring as short as possible to avoid communication problems.
Halvor[/quote]
I have two K8095s with SD card slot attached via ca. 25 cm ribbon cable. No problems encountered.
The sound quality is more than enough for in-car use.
I have replaced the innards of a 1956 Cadillac radio with K8095, and attached the pushbuttons to radio controls.
See http://nagi.ee/photos/olevtoom/sets/306987/
Very satisfying So I can only recommend the kit.
