K8095 mp3 file size bigger than 10Mb
I have an k8095 kit. It is workink ok with mp3 files smaller than 10Mb, but if the file is larger, it is played with distortions and the buttons are not responding until the mp3 ends.
Is this a known issue?
No such issue reported so far.
I tested the K8095 and VM8095 with a 165Megabytes MP3 file with bit rate 320kBit/s and sampling frequency of 44.1kHz without any problem.
Can you please check the properties of the problematic MP3 file e.g. what is the bit rate and sampling frequency.
The K8095 and VM8095 support bit rates up to 320kBit/s.
I noticed the problem appears with a specific 4 GB SDHC card (SanDisk SDHC, 4GB, speed class 4).
I uploaded two mp3 files bigger than 10MB on this card, and they are not played ok, even if they are correctly played from a different 4GB SDHC card.
If the files are smaller than 10MB, they are played OK from all cards.
The files are 44100Hz stereo 320Kbps.
