I recently bought the K8088 (RGB controller). When i wanted to assemble it, i saw something unusual.
The buttons with which you change the effects, are in the inside. I can’t reacht them when the box is closed.
Is this normal?
Greetz
Is this normal?
Greetz
Yes, this is normal.
This is a product which needs to be configured once, before using it.
If you want to be able to change colour/intensity/effect/etc… during operation, you should choose a different product, depending on your application or you could drill holes in the enclosure and mount longer buttons.
Do not try to extend the buttons by adding wires as correct operation cannot be guaranteed.
