I used the K8084 and it works perfect. The only disadventage I had was with a standard transformator. A Toriod is much better in my case. I had a lot of HUM…and grounding didn’t make it much better. I also made direct connections to the print instead of using the RCA connections on the print.
Here You see my results:
(on the bottom…input…on top…output) with a 1kHz 0dB test sound from CD.
if someone build this like in the picture…pay attention that the mounting system (the metal in the middle of the toroid transfo) never connect to both sides of the case. This will result in a problem!!! It will act as a single winding and gives a short-circuiting!!!
