just want to share my experience with using the K8076 PIC programmer from Velleman on a Windows XP computer.
After assembling the programmer, I tested everything (with multimeter) before connecting it. Everything seemed fine, so I continued and plugged in the power.
Trying to write to a new 16F628A PIC I got the message that some settings didnāt match something else (you know, the famous error message of PICProg2006) or that no programmer was connected. However, the diagnostic LED test was running fine.
I tried all settings, configurations and options in that program, and I also tested my serial cable, tested the power supply and different PICs, but nothing helped. Then I tried to disable the FIFO buffers of my COM port (under device manager -> COMx properties -> Port settings -> Advanced) and supprise, everything worked. Since I disabled this FIFO buffer setting of my COM port, no new programming attempt ever failed againā¦ maybe the buffers are messing up some timings while programming the PIC?
Not being able to find anything related on the internet (at least before I solved this problem), I hope this might help some people that have had the same problem as I didā¦ I searched days for a solution, but did not find any.
It would be nice to have other people confirm or disconfirm what I just wrote and to get some feedback here
still have the āsettings donāt match pic in programmerā error. I can read the data but not write. If i connected the programmer to my old computer with windows 98 it works fine.
my board works fine on my older computer (running windows 98) so i donāt think anything is wrong with the connections or board. I just think the kit is not compatible with modern com ports :?
I could use the older computer the only problem is that the picprog2006 crashes when u click the button to find out where to place the wires on the board (in windows 98) :roll:
no i used to run windows xp on that computer but there is something wrong with the memory or some device that gives me āblue screens with error messageā when i try to boot or install windows xp
I only have windows 98 and XP on cd so i canāt try any other windows to install.
