K8064 question
hello
New user so am unsure if I’m in the right bit of the forum.
I have just put together a K8064 kit, and when I plug it in I get the red led flashing four times, then going off. The light that I have attatched to it works, but the green led never goes on. Can someone point me in the right direction as to what I might be doing wrong?
Cheers
K
check every contact, look in the manual, it will have a code to the number of LED flashes and what it indicates.
I hope I have hepled!
Looks also to me as an assembly problem.
Attention, every part is on high voltage !!!
Check every component and solderjoint twice before plug-in the power.
