K8061 initialisation
When i click connect i get the message cpu fail.i installed drivers and copied dlls to appropriate locations.can you help me?it recognises that card and write that its connected but its written cpu fail and demo not working.i use win7
Please check the LED LD12 is flashing when the power adapter is connected and the USB cable is disconnected.
Does the LD12 stop flashing when the USB cable is connected? - Should stop flashing.
Are LEDs LD9 “USB” and LD10 “POWER” lit when the USB cable is connected? - They should be lit.
Please check the optocouplers IC1 and IC2 are correctly positioned (check the notch).
Does the drivers work on vista?
I succeded. My board works just fine.Thank you.Only one question more.
All leds on digital inputs are lit. When i run the application and try to turn them off i dont succed.Could you help me?
[quote]All leds on digital inputs are lit. When i run the application and try to turn them off i dont succed.Could you help me?[/quote]This is normal. You get the input LED off by connecting the digital input terminal to GND.
Which operating systems are supported?
[quote]Which operating systems are supported?[/quote]Windows XP, Vista, Windows 7 and 8.
Is it possible to suggest that velleman make board with 6 pwm’s on format of vm167 board for robotics?
[quote]Is it possible to suggest that velleman make board with 6 pwm’s on format of vm167 board for robotics?[/quote] Thank you for the feedback. Any and all suggestions are welcome.
This feature may be considered for future product releases.
